So I found out that ethernet had been pulled to every room in the house except mine when we moved in. I had always assumed we had a cable sitting in the outlet, but apparently not, so now I find myself needing to connect to wi-fi. Can I cheap out on a wifi card for $10? How much does a more expensive one cost, and assuming the price range is $20 what would you recommend?
Tip to those that are new on LTT forum- quote a post so that the person you are quoting gets a notification, otherwise they'll have no idea that you did. You can also use a tag such as @Ryoutarou97 (replace my username with anyone's. You should get a dropdown after you type the "@")to send a notification, but quoting is preferable.
Feel free to PM me about absolutely anything be it tech, math, literature, etc. I'll try my best to help. I'm currently looking for a cheap used build for around $25 to set up as a home server if anyone is selling.
If you are a native speaker please use proper English if you can. Punctuation, capitalization, and spelling are as important to making your message readable as proper night theme formatting is.
My build is fully operational, but won't be posted until after I get a GPU in it and the case arted up.
https://linustechtips.com/topic/554272-help-needed-choosing-a-wireless-card/
Here would be my cheap recommendation: http://pcpartpicker.com/part/tp-link-wireless-network-card-tlwn781nd
The better (Intel recommendation -- I've always had better experiences with Intel cards): http://pcpartpicker.com/part/intel-wireless-network-card-7260hmwdtx1 Although, I will admit, I didn't take my advice this last time and I got an Asus PCE-AC56 and I couldn't be happier with it....so take all of this with a grain of salt (the above TP Link should be fine).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Get a cheap TP-link PCIe card. It's the one that tops Amazon's bestselling list.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
Thanks!
