Cooler help: Case + CPU
Go to solution Solved by Streetguru,
51 minutes ago, Kecchi said:
A hyper 212 would be fine, look for 120mm fan 4 packs if you want more airflow
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103052
http://uk.pcpartpicker.com/p/qQ8h4D
I already have a PC but I want to lower the temps in the case for the GPU (EVGA 960 2GB) and mainly the CPU which is currently using a stock cooler.
I have a i5 6600k which I would love to overclock but the temps are terrible.
Can I have recommendations on what CPU cooler to get and with what to replace the case fans with.
EDIT: Looking at https://www.scan.co.uk/products/120mm-noctua-nf-f12-industrialppc-3000rpm-pwm-high-performance-fan for case fans?
EDIT 2: https://www.scan.co.uk/products/cooler-master-hyper-212x-tower-cpu-cooler-4-heatpipes-1x-120-pwm-fan for CPU?
No suggestions? :( Did I choose the right stuff?
1 VAC ban(s) on record Info
0 day(s) since last ban
https://linustechtips.com/topic/554189-cooler-help-case-cpu/
https://linustechtips.com/topic/554189-cooler-help-case-cpu/#findComment-7306116
