Wha....? you need a cpu cooler to run ARK?
wat
I think you mean you just need a cpu cooler for temps not to run ARK....
212 Evo?
idk if that fits....
i dun know nuffin' about amd cpus
or does your cpu get really hot and it thermal throttles?
either way
212 evo :D
https://linustechtips.com/topic/553738-cpu-cooler/#findComment-7300642
The 212 evo is definitely a great cooler for the price
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/553738-cpu-cooler/#findComment-7301510
