I am planning on upgrading my system to be liquid cooled in the near future and was wondering if the hardware I have will support it, as well as keep everything cool enough.
The case I am using is a Corsair Vengeance Series C70 Military Green Steel ATX Mid Tower case, and MSI motherboard (can't recall the exact model; might swap this out), Intel Core i7 4960X CPU (might upgrade), EVGA GForce 980ti (might get a second one for SLI), 16 GB of ram, I think I have an 800 watt hydra power supply installed (will be swapping that for a modular power supply), an SSD for my boot sector and a normal HDD for files. I am aiming to have a yellow/green theme for the build. This build is for gaming and would like to have it run cooler and as quite as I can get. Any tips and suggestions would be greatly appreciated.
https://linustechtips.com/topic/553409-upgrading-to-liquid-cooling/
4960x.. U mean K? And the cpu is already bottlenecking the 980ti so one more 980ti is useless.. EK-wb och bitspower is the two manufacturers that are the best (what I think)
*Hex gear R40 black *Asus z97-i plus *Intel i7 4770k *16gb Hyper beast RAM *Asus GTX 970 strix *EVGA G2 750W *Samsung EVO850 500GB *Samsung EVO850 500GB *Asus MX299Q *Audioengine d1 *Beyerdynamic dt 990 *Blue Yeti Blackout edition *Ducky Shine 5 RGB *Ducky Secret * Ducky mousemat *Custom loop
So would it be better to get a better CPU before I go any further with my upgrade?
well it depends, in 1080p the 980ti is nearly too good.. it works best in 1440p or higher. if u want the cpu to be in the same grade as the gpu i would rekomend 5820k, 5930k or the 5060x :) the 4690k is a mid end cpu and the 980ti is a high end gpu :) thats why the cpu is a bottleneck. dont get me wrong, its still a beast and the 4690k is a very good i5 cpu :)
He's got a 4960X, completely different beast. The performance gains he'd see from switching to a 5820K would be minimal.
wow. sorry this is my foult.. never heard and never seen of the 4960x cpu in my country! so so so sorry! if thats the case the upgrade to a new cpu is not requierd! and again sorry! <3
Lol glad to see that confusion got cleared up.
1: Your hardware is perfectly fine for watercooling.
2: What are you planning to do with this PC? Gaming? Rendering? What else?
3:How much are you planning on spending on the Liquid Cooler?
4: Are you planning on doing any overclocking? How much overclocking?
