Password Protection Help
Go to solution Solved by IndaLight,
8 minutes ago, MrUnknownEMC said:
LastPass. The usb i think it like second authentication method.
I googled lastpass and found what I was looking for which was the YubiKey NEO. Thanks.
I know there' a lot of software that could help but I was wondering if there was a physical password protector. I remember seeing a USB device about the size of a flash drive and you plug it in then every single time it generates a new password or it remembers them. I forgot ....please help.
https://linustechtips.com/topic/553314-password-protection-help/
Magical Pineapples
https://linustechtips.com/topic/553314-password-protection-help/#findComment-7296072
