k70 RGB key press problems
Hey Linus tech tips forum :)
I have a corsair k70 rgb with cherry mx blues.
sometimes when i press certain letters on the keyboard (fx. the letter "E") it types it multiple times when i only press it once.
i really find it annoying when i try to type something and it times 2-3 extra letters instead of 1.
help please.
-Syde
https://linustechtips.com/topic/552912-k70-rgb-key-press-problems/
Try different bios setting on the back of the keyboard there is a switch.
If it doesnt help, can u try keyboard on a different machine ?
If nothing helps, RMA it asap.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
ok i tried the keyboard on a different computer.
same thing. i tried with and without the cue software. no difference.
i guess i'll have to RMA it. :(
have u tried to move the switch on the back ? there are numbers 1 2 4 8. Mine is on 1.
He said he tried it on a different computer so the BIOS switch is irrelevant.
He needs to either RMA or solder on a new RGB MX Blue switch.  And those switches aren't currently buyable from anywhere (the non RGB MX blues are, but that won't help), so he has to RMA it.
