Just get the cheapest thing you can that's from a well-known brand. Most people put too much thought into their power supply when it's not necessary; all power supplies sold in the EU are safe for use up to their rated current. Your computer will never pull 650 watts so it's ok.
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7290236
3 minutes ago, SunnySingh said:
hundred Australian dollars
71.92 usd dollars
How about something like this?
https://www.pccasegear.com/index.php?main_page=product_info&products_id=33118&cPath=535&utm_source=googlebase&utm_medium=cse&utm_campaign=export_feed#googlebase
Now I know it's not quite 650 watts but your computer will barely sip 400w overclocked so it's fine.
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7290250
Now I know it's not quite 650 watta but your computer will barely sip 400w overclocked so it's fine.
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7290257
Perhaps this one?
it's 750 Watt for around 64 USD
http://pcpartpicker.com/part/corsair-power-supply-cx750m
or this evga 750 watt PSU for around 70 USD
http://pcpartpicker.com/part/evga-power-supply-110b10750vr
PC1: i7-6850K, X99A godlike gaming carbon, 1080 ROG strix a8g, 4x8GB fury black, 120GB 840 evo, 3TB seagate, 5TB ext
PC2: HP Pavillion G6 i7-3612QM, AMD 7670M 1GB, 2x4GB sodimm, 250GB 850 evo & 750GB Hitachi HDD
PC3: Raspberry PI2
Phone: Galaxy S5 (G900F)
Watch: Galaxy gear (V700)
Tablet: Samsung Tab E 9.6 (SM-T 500)
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7290293
Just now, dinnozo said:
Perhaps this one?
or this evga 700 watt PSU for around 70 USD
aren't they to too much
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7290297
Provide us link of website from where you would like to order PSU and we will give you opinion for best PSU in your price range.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7290315
650W is kinda alot for a GTX 780. You wouldn't run into any problems if you just ran with a simple 500W PSU.
Best bet would be to grab a 520W Antec HCG - reliable, semi-modular and relatively cheap:
http://au.pcpartpicker.com/part/antec-power-supply-hcg520m
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7290496
7 hours ago, SunnySingh said:
Any suggestion on 650W power supply for an gtx 780
PSU whitelist in my sig can help you out.
https://linustechtips.com/topic/552791-i-need-a-power-suply/#findComment-7292228
