Switches.
BlackHat2000
So I've been running off Wi-Fi for a while and am making the change to wired. My router is upstairs and was thinking with my cave having all my stuff, a gigabit switch would be fine for my appliances. Is that correct? I don't wamam fuq it up
You will probably want to look for an unmanaged switch. They're mostly plug and play. Plug in WAN from your modem and then you can load up the ports. If you want to get into more detailed stuff, QoS, LAG, vLANs you would have to get a managed switch. Those can be found in the secondary market for fairly cheap if you're lucky. New they can go for quite a bit, 250+ easy.
CPU: i7-4770k @ 4.5GHz 1.2vCore     GPU: EVGA GTX 780 @ 1202/1762     RAM: Corsair Vengeance @ 2133MHz (11-11-11-27)     MOBO: Asus Z-87 PRO     PSU: Corsair AX860     SSD: 2x256GB Samsung 840 PRO     HDD: 1TB WD Black     CASE: Fractal Design Arc Midi R2
