After updating my drivers, I saw a new feature called, "Switchable Graphics Application Monitor"
When I clicked on it, and clicked on Start Monitoring, this came up:
Everything was on Power Saving. So, I plugged in my laptop, put it at High performance, and set the "Switchable Global Graphics Settings" to Maximum Performance.
Then I went into the "Switchable Graphics Application Settings", and set Just Cause 2 to High Performance...
Then, I did the monitoring thing again, and it still said Just Cause 2 was on power saving....
Here is my laptop: http://www.newegg.com/Product/Product.aspx?Item=N82E16834215663
I upgraded the ram to 8gigs if that would help...
Any suggestions on how to fix this?
https://linustechtips.com/topic/55218-amd-graphics-power-saving-problem/
Do you see an actual performance change in games?
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
