2 minutes ago, PheonixOne said:
While trying to set up a VM (any OS, linux, windows) i get the following error : timed out after 60001 ms waiting for child request #1
Can anyone help me out? I cant find the solution
Have you enabled VT-d?
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
1 minute ago, Jstone said:
Ive been trying to for the longest time so my macbook doesn't just site around collecting dust. Is there a tutorial you used? Every time I try to get it to go it wont due to no bootable device
a friend of mine has a mac, he used this tutorial :
If you have any questions about the settings or how to get the ISO's or anything else message me, im happy to help, you can get free open source OS's since pirating them never ends well - i wouldnt advice pirating OS's at all!
12 minutes ago, PheonixOne said:
Yep thats enabled!
Do you have Avira antivirus? Try disabling it.
Nope, using bullgaurd.. But it seems if fixed the issue, not sure how i did it - but it worked, thanks for the help anyway :)
It fixed itself? Ah, typical of VB :D
