15 hours ago, KuJoe said:
How often are you getting a DDOS attack? I think your main problem is stop getting your home network DDOS'ed (i.e. use a VPN).
The little boi has my IP, and its regularly. VPN won't stop it since it's from only one person
https://linustechtips.com/topic/552076-att-static-ip-problem/#findComment-7283341
Then go ahead and order a new modem if that's all it takes. Once you get your new modem setup a VPN immediately.
That doesn't answer my question, I would have already ordered a new modem if I just wanted a new Ip address.
I'm looking for a dynamic IP, not a static one. Which ATT is refusing to set me up with one claiming I already have a dynamic IP.
https://linustechtips.com/topic/552076-att-static-ip-problem/#findComment-7283355
Are you hosting a server?>
"In the middle of every difficulty lies opportunity."
- Albert Einstein
https://linustechtips.com/topic/552076-att-static-ip-problem/#findComment-7283361
If they assign a static IP like you are saying then there's no way for you to change that unless you work for them. If you have a dynamic IP like they are saying then unplug your modem for a few hours/days and when you plug it back in you should get a new IP address.
-KuJoe
https://linustechtips.com/topic/552076-att-static-ip-problem/#findComment-7283363
Jesus christ guys, I just had one question, if I buy a third party modem, will I be assigned a dynamic IP?
You'll get a new ip, but not a dynamic one.
- Albert Einstein
https://linustechtips.com/topic/552076-att-static-ip-problem/#findComment-7283391
