Hello guys,
i want to build my first gaming pc and need some help with it, here is the part list:
http://de.pcpartpicker.com/p/cGTKYJ
I planned to use an 1440p monitor at first, because im not sure about 4k. Would it be able to run 4k gaming? (maybe the same grapics card again in SLI?)
I'm not a native english speaker, so please don't blame me for my issues! :/
If you don't understand somethink I'm writing please tell me!
https://linustechtips.com/topic/551646-gaming-pc-build-need-help/
I'd do this, DX12 is gonna want more cores:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (€393.20 @ Mindfactory)
CPU Cooler: Phanteks PH-TC12DX 68.5 CFM CPU Cooler  (€49.90 @ Caseking)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  (€6.90 @ Caseking)
Motherboard: MSI X99A SLI PLUS ATX LGA2011-3 Motherboard  (€215.79 @ Mindfactory)
Memory: G.Skill Ripjaws V Series 32GB (4 x 8GB) DDR4-3000 Memory  (€194.95 @ Mindfactory)
Storage: Samsung 950 PRO 256GB M.2-2280 Solid State Drive  (€186.86 @ Mindfactory)
Storage: Seagate  2TB 3.5" 7200RPM Hybrid Internal Hard Drive  (€97.27 @ Mindfactory)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  (€666.41 @ Mindfactory)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  (€166.93 @ Mindfactory)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (€127.89 @ Amazon Deutschland)
Case Fan: Phanteks PH-F140SP_BK_WLED 82.1 CFM 140mm  Fan  (€23.43 @ Mindfactory)
Fan Controller: BitFenix Recon (White) Fan Controller  (€39.90 @ Amazon Deutschland)
Monitor: Dell U2715H 60Hz 27.0" Monitor  (€299.00 @ Amazon Deutschland)
Other: Cable Sleeve (€8.90)
Other: Cable Sleeve 2 (€6.73)
Other: PHANTEKS Enthoo Luxe Multicolor LED-Strip - 2m (€30.83)
Total: €2561.75
Generated by PCPartPicker 2016-02-20 17:26 CET+0100
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Total: €2561.75
This except you don't need 32 gb RAM.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
yes I agree (however I did under 4k gaming, "low system memory crashes with 16gb /shrug), I cant recommend 4x4gb, just think if you're buying 4 sticks (quad channel) then go with 4x8gb, saves replacing the 4gb sticks further down the line
Ryzen Ram Guide
Can you explain to me why I should take an diffrent CPU? Wasn't the one before better?
And whats about the motherboard, why a diffrent one?
Sorry guys! I hope you are understanding what I'm writing here :/
Direct X 12 which is incoming will benefit much more from the extra cores of the 5820K. An i7 6700K has 4 cores + 4 threads making it appear to have 8 logical cores (emulated if you will). A 5820K has 6 physical cores + 6 hyperthreading making it appear to have 12 logical cores.
You need a different motherboard as the 5820k requires a different chipset to that of the 6700k, 2011 pins vs 1151
Ryzen Ram Guide
So the rest of the system is good to go with 4k? Or is there a better CPU/Graphicscard that i could buy?
I wouldn't really aim for 4k at the moment, hardware isn't quite there without spending a lot of cash. a 980ti will run most games at 4k with high detail settings, but like my 970 sli set up. it will struggle with some later games, although by that point you could add another 980ti. Personally I feel 1440P is the sweet spot at the moment
Ryzen Ram Guide
Total: €2561.75
Also, DX12 using more cores is still a rumor.
alright, so I could build it like this and use it on 1440P and later upgrade it to 4k with another 980ti?
Maybe so, but early indications seem to point to it as a fact:
http://www.pcworld.com/article/2971612/software-games/windows-10s-radical-directx-12-graphics-tech-tested-more-cpu-cores-more-performance.html?page=2
http://wccftech.com/amd-r9-290x-fast-titan-dx12-enabled-3dmark-33-faster-gtx-980/
I know the evidence is very limited at the moment, but I would still take the 5820k over the 6700k (especially due to the 6700k's inflated price at the moment) as it is the superior platform
Ryzen Ram Guide
26 minutes ago, KrandeKraft said:
Hello guys,
Just one word of advice: Once you've picked your parts, be sure to look them up on geizhals.de. You might be able to save another 100,- Euros this way.
4 minutes ago, Starelementpoke said:
Honestly, the build suggested is overkill for 1440p.
I woundn't say so, its going to be near identical performance to my rig and some games I'm running along at 50FPS 1440P fully maxed. If the OP does indeed SLI 2x 980ti then yes I would recommend 4k, but keep in mind a single 980ti is going to struggle at max settings 4k in a years time, if not less (albeit only on latest AAA titles)
Ryzen Ram Guide
The 3dmark one I'm not surprised, doesn't that test have a physic's benchmark? The ashes one I can't say the same about.
You could buy the 4k monitor now, run 4k and just drop the resolution to 1440P when/if the 980ti begins to struggle. That would save switching out the monitor at a later date.
Ryzen Ram Guide
What's your gpu memory usage look like? In what games?
Would the qualitiy be still the same like on a 1440p monitor? Or are there some difficultys doing this? Drivers still work correctly?
Lol I'm not anywhere near the imaginary Vram stutter lol, not at 1440P anyway. Depends on the game really, this weekend I have been playing beta's for the Division and Black Desert so they aren't a good measure as still beta.
Games I have been playing around that FPS with max settings (maybe not full MSAA)
Rise of the Tomb Raider
GTA V
Fall Out 4
Far Cry 4
Witcher 3 (50 - 80 FPS @ ultra settings)
MGS V
AC: Syndicate
TC Rainbow Six:Siege
Ryzen Ram Guide
GTA V
Fall Out 4
Far Cry 4
MGS V
AC: Syndicate
You got a Black Desert Beta Key too?
Drivers won't be an issue at all. I have a 4k TV hooked up to my rig and sometimes wanna just chill on sofa with a gamepad and play some 4k. It runs a lot of games fine at 4k, others are a struggle, most notably AC:Unity and Rise of th Tomb Raider. Those 2x games I run @1440P and the scaling isn't an issue, however I can't speak for specific 4k monitors as to how well the downscale
Ryzen Ram Guide
Ye, but I actually bought the game and didn't need it, I posted the key up I received a few days ago to the forums
Ryzen Ram Guide
Sooo... I thought about it and I think I'm buing a 4k monitor, I'm not sure but I think I will try to use the i7-6700k as planned (do you think i would still work or do you really reccomend the other one?), but your idea with the ssd is good, but I actually need a bigger one like this: https://de.pcpartpicker.com/part/samsung-internal-hard-drive-mzv5p512bw
This is a very fast thing, or? It uses PcIe right?
http://de.pcpartpicker.com/part/asus-motherboard-z170deluxe
This motherboard has only 2x PcIe, right?
there is the problem: If i want to upgrade my pc later, there is now PcIe slot left for the second card...
Is this card better than the one before? because of sc? https://de.pcpartpicker.com/part/evga-video-card-06gp44995kr
Do you know a good cheap 4k monitor?
That SSD is a solid choice, the 512gb actually performs a little better than the 256gb.
I'm not sure about the PCIE, but I know that board offers 32g/b sec m.2 which is plety fast enough:
 https://www.asus.com/uk/Motherboards/Z170-A/
The EVGA is a solid choice also, they have the best customer support and offer the step up program, they are my "go to" brand for Nvidia
I would still say to go 5820K, however the choice is yours. For gaming the 6700K will perform better out of the box, the 5820K would need to be overclocked to perform the same. But anything using more than 4 cores the 5820k will out do the 6700k, especially if its overclocked.
As for 4k monitors, depends on your budget?
Ryzen Ram Guide
