GTX 970 Overlocking Help
Go to solution Solved by Low_Battery,
10 minutes ago, 1Revenger1 said:
Hi, so I have been interesting in overclocking my GTX 970 lately (MSI Twin Frozr), but I've been really wondering what the best way to go about it is. I have looked online, and I get that you usually go up in increments with usually the memory core clock first, then the other. The main question I guess I have is what do I do with the voltage? I am using afterburner and all I see is the power limit. If there is also some nice guides I've missed, those would be appreciated as well.
Thanks, sorry if I missed something I really shouldn't have missed :P.
Try OC'ing without increasing the voltage at first (you can increase the power % offset though). Once you start getting unstable, then try upping the voltage in low increments.
Current system: CPU:I5 6600k 4.5Ghz, CPU Cooler: Asetek 550LC, Motherboard: Asus Z170 Pro Gamer, Ram:Adata XPG 4x2 2400, Graphics Card:MSi GTX 970 + Zotac 970, Hard drives:256gb SSD+1tb WD Blue, Case:Corsair Spec 01 Power Supply:XFX TS  750 watt Bronze, OS:Windows 10 64bit
https://linustechtips.com/topic/551208-gtx-970-overlocking-help/
https://linustechtips.com/topic/551208-gtx-970-overlocking-help/#findComment-7274667
|[ i7 6700k ][ MSI z170a XPower Gaming Titanium MB ][ 16gig G.Skill Trident Z 3000mhz ][ Gigabyte Xtreme GTX 980ti ][ Samsung Evo & Intel SSDs ][ Corsair 540 air ][ XFX Pro 750w Platinum ][ 24" Asus 144hz ]|
https://linustechtips.com/topic/551208-gtx-970-overlocking-help/#findComment-7274726
Ok, that helped to clear everything up. Thanks.
https://linustechtips.com/topic/551208-gtx-970-overlocking-help/#findComment-7274827
