CPU Fan Help
Solved by lildog,
You at least need a CPU cooler of some sort because the 6700K doesn't include one. Also since you're buying the K I assume you're going to be overclocking so yes you should get a nice cpu cooler with a fan, or a huge passive cooler and a lot more case fans (worst option cuz will be louder in the end with all the fans), or look into liquid cooling. If you're not looking to overclock then you probably shouldn't get a K processor and those will include a stock cpu cooler which should be sufficient.
