This is going to sound stupid.
How hot can a radiator be before it gets a little bit risky? The one I'm using is very hot and I'm wondering how much heat it can take. Its a 240mm
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/550005-very-hot-radiator/
As long as liquid temp doesn't go much past 50c, you should be OK.
A lot of pumps can be damaged by high liquid temps.
(Usually the rad will be close to liquid temp)
https://linustechtips.com/topic/550005-very-hot-radiator/#findComment-7261831
Just now, ELSknutson said:
whats your temps?  also your hardware will break before the radiator will. also the tubes will give out before the actual rad does.
The temps are fine. (No higher than 50C so far) Its just a random question really.
https://linustechtips.com/topic/550005-very-hot-radiator/#findComment-7261837
well most CPU's give out at about 100c
the tubes depends on material  but car rads typically run in the 200c range so I dont see the tubes lasting much further then that
Gotcha. Thanks.
https://linustechtips.com/topic/550005-very-hot-radiator/#findComment-7261870
