Hey
I have been looking for a case in a very long time and recently i've falling in love with clean designs.
So far i've been looking on Fractal design Arc XL, Bitfenix Shadow and Corsair 800D.
As you can see im going with a fulltower!
But do you have any suggestions there is better?
My budget is around 200 Euro
-Thanks
https://linustechtips.com/topic/54863-clean-simple-modern-case/
Have you taken a look at the phanteks enthoo primo? It has been getting fantastic reviews, but isn't out yet. The corsair 750d should be coming out soon. Nanoxia has some nice cases they are a direct competitor to fractal designs define series.
https://linustechtips.com/topic/54863-clean-simple-modern-case/#findComment-737020
Are you planning a full build if so it's better not to assign budgets to certain parts, If you actually need a full tower waiting for the 750d could be a good idea as it looks really clean  if not the shinobi xl has quite a clean design as it looks really clean do you need a full tower case though
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/54863-clean-simple-modern-case/#findComment-737032
BitFenix shadow is a very nice looking chassis but it doesn't have support for dual 120mm radiators, so you won't be able to use a h100/h220 in there. The BitFenix Shinobi XL would be a better choice.
CPU: Ryzen 5 3600 @ Stock, CPU cooler: Dark Rock 4, Motherboard: MSI B450M PRO-M2 MAX, RAM: 2x8GB Crucial Ballistix DDR4 @ 3000Mhz, GPU: EVGA GTX 1080 ACX 3.0, SSD: Crucial P1 1TB M.2 + 2x120GB SSDs, Case: Corsair 110R, PSU: Corsair TX650M, OS: Windows 10 64-bit.
https://linustechtips.com/topic/54863-clean-simple-modern-case/#findComment-737156
I would not get the Bitfenix Shadow because imo it is lacking in terms of airflow in the case. I would either get the Arc XL because this case has great airflow imo.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/54863-clean-simple-modern-case/#findComment-738054
I second that, it'll be the case for my upcoming build  :)
CPU: Intel i7-4770k MOBO: Asus Maximus VI Formula RAM: G.Skill RipJawsX 2x8GB 1600Mhz GPU: Asus GTX 780 DCuII CASE: Phanteks Enthoo Primo STORAGE: ADATA SX900 256GB / WD Caviar Blue 1TB PSU: Corsair AX760 760W MONITOR: Dell Ultrasharp U2312HM KEYBOARD: Ducky Shine 3 MOUSE: Logitech G602 http://linustechtips.com/main/topic/106614-project-insert-name-enthoo-primo-rigid-acrylic-red/
https://linustechtips.com/topic/54863-clean-simple-modern-case/#findComment-738203
you lucky
https://linustechtips.com/topic/54863-clean-simple-modern-case/#findComment-738219
