Asus Xonar DSX problem
I got a sound card called the Asus Xonar DSX and the headphone jack seems to be faultly since sound only comes out of one headphone. I have disabled the HD audio in the bios then installed the driver. The port I used was AC97 (whats the difference from HD audio port?).
Is there a fix or am I going to have to send it back?
https://linustechtips.com/topic/54855-asus-xonar-dsx-problem/
Welcome to the Xonar Owners club! You've successfully completed our one requirement of membership: having a technical issue with the card.  :mellow:
https://linustechtips.com/topic/54855-asus-xonar-dsx-problem/#findComment-736937
Why don't you just plug it straight into the back of the card?
https://linustechtips.com/topic/54855-asus-xonar-dsx-problem/#findComment-736979
