8 minutes ago, MrPulsee said:
Hi, i'm looking for any suggestions as to what parts i'll need to build a BUDGET...... BUDGET........ one more time... BUDGET PC. I currently have an i5 750 cpu with a compatible evga mobo and a case. I'm looking at right around $250 as a budget currently.
Used 280x/7970/7950 - $100-150
Used 500w PSU - $50
8GB kit - $35
Total = $185-235.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/547972-console-killer-pc-help/#findComment-7239974
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($164.99 @ Newegg)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($53.99 @ SuperBiiz)
Total: $268.87
Generated by PCPartPicker 2016-02-14 20:23 EST-0500
just went $16 over it.
New: PCPartPicker part list
Old:Intel® Core2 Quad CPU Q8400 @ 2.66GHz, GIGABYTE GA-EP43T-UD3L, 4 GB Elixir PC3 ddr3-1333,  ASUS RADEON R7 260X, Thermaltake M9, 1TB HDD, GreatWall GW550SEL 550 WATT, BENQ GW2255, Hyper T4, Samson SR950 Headphones, fiio ek10.
https://linustechtips.com/topic/547972-console-killer-pc-help/#findComment-7239982
5 minutes ago, MrPulsee said:
Honestly couldn't tell you at the moment. It's sitting in a closet with a whole bunch of other PC parts. all i know is that it came off of a i5 750 build awhile ago
CPU: Intel Core i5-750 2.66Ghz Quad-Core OEM/Tray Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: EVGA 123-CD-E635-KR ATX LGA1156 Motherboard
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($30.99 @ Amazon)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $161.75
Generated by PCPartPicker 2016-02-14 20:26 EST-0500
Then look around for a used 660, 7850, 7870 around that range.
Steve
https://linustechtips.com/topic/547972-console-killer-pc-help/#findComment-7240000
