Current build is
MOBO: Crosshair V Formula Z
GPU: Gigabyte 770 4Gb V Ram
CPU:  AMD FX 6350 3.9hertz
PSU: Corshair 750w
RAM: DDR3 Vulcan 2400 hertz 16gigs
I am looking to upgrade my MOBO to Asus Hero VIII, Upgrade my CPU to Intel's new I7-6700K 4.00 GHz 8M Processor Cache 4 LGA 1151" then change my Ram to Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 2666MHz (only getting 2 sticks to save up more money for expanding later)
So HERE is my question. I assume my current build/processor is bottlenecking my 770. So! With this new parts, should I see a dramatic increase in performance? OR should I shell out some extra money and get the Gigabyte 980Ti G1 Gaming? I am thinking that since the 900 series came out in 2014 they will most likely come out with a new series soon and I don't want to shell out a bunch of cash for a card that will be "outdated" soon.
I am content with my gaming performance for now. So, I assume the 770 would work even better with these newer parts. Should I wait on the GPU and save my money on a newer series on Nvidia cards?
https://linustechtips.com/topic/547885-pc-build-for-2016/
Compared to a FX 6350 you'll probably see some pretty good performance upgrades in games. Not insane, but good depending on the games you play.
The only thing I would advise is getting cheaper RAM, as it doesn't make a huge impact. (Barely any tbh)
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/547885-pc-build-for-2016/#findComment-7239157
@Sorkurie Compared to FX 6350 you may see max 20fps increase in games! The 63xx series is equivalent to an i3 so the performance will be increased a lot :)
If you want a reply PLEASE QUOTE ME!
WE NEED CUSTOM MEMBER TITLES AGAIN!!!!!
Member title post link!
https://linustechtips.com/topic/547885-pc-build-for-2016/#findComment-7239191
I would look at some 770 benchmarks and then compare them to your own. If there is a significant difference then maybe look at switching out your cpu. Maybe an i5 6500 if you are looking for a mid range chip that will unlock your gpu's potential. Or even something that still works on the AM3+ platform like a 8350 or higher. In terms on GPU upgrades, I would  wit for the next wave of AMD and NVidia cards to roll out and then either make an educated purchase of a new card or grab an old card for a discounted price.
I'm here to help people and have fun. Feel free to chat!
i5 6500
Asus Z170-AR
Saphhire Nitro 380X
 Hyper X Fury Black 16gb (2x8gb) 2133
https://linustechtips.com/topic/547885-pc-build-for-2016/#findComment-7239279
