http://www.amazon.co.uk/gp/product/B0084LZJ1M/ref=noref?ie=UTF8&psc=1&s=computers
This is currently lowest price of the drive anywhere...
Is this drive better than the other 3TB drives out there for the price? (if you need 3tb)
I'm under the impression its just a seagate barracuda 3tb inside a external cage? (which is more expensive to buy than this for some reason o_o)
Thanks!
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/54714-3tb-hard-drive/
It doesn't make a difference for an external hdd.
https://linustechtips.com/topic/54714-3tb-hard-drive/#findComment-735255
It's just a 3tb barracuda you can just take it out of the enclosure and put in your desktop.
https://linustechtips.com/topic/54714-3tb-hard-drive/#findComment-735282
Is sata 6 faster than usb 3.0?
Also does it void the warranty if you remove the drive from the enclosure?
https://linustechtips.com/topic/54714-3tb-hard-drive/#findComment-735314
Yes, it'll void warranty.
Off the top of my head, SATA 3 is at max 6 gbit/s whereas USB 3.0 is 5gbit/s.
So will using sata instead of USB 3.0 be noticeably faster for transferring and accessing files?
Would rather not void the warranty...
My current 2tb WD drive has 50gb space left and that's going to be filled very quickly, its also on its way out (its so old)....so I'm in dire need of another drive.
https://linustechtips.com/topic/54714-3tb-hard-drive/#findComment-735426
It will make no difference. The average transfer speed of a modern HDD would not be bottlenecked even by SATA I (1.5 Gb/s), so you will not be held back by the USB 3.0 interface.
You might be held back by USB 2.0.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/54714-3tb-hard-drive/#findComment-735465
Ok then I can just keep it as usb 3 then.
Thanks.
https://linustechtips.com/topic/54714-3tb-hard-drive/#findComment-735496
If you are using your ssd as the os/boot drive, you should be fine with usb 3, though there might be some issues from time to time. Personally, I would prefer to not have too many external devices, but if you really don't want to void your warranty, it should be fine with usb 3
CPU: Intel 3570k (4.3) MOBO: Asrock z77 extreme6 GPU: Gigabyte Windforce HD 7970 RAM: 4x4 Gb Samsung Ultra Low Profile DDR3-1600mhz CPU Cooler: Coolermaster Hyper 212 Evo Storage: 250GB Samsung 840 Pro SSD (Boot), 3TB Seagate Barracuda Case: NZXT Phantom 410 (black)  PSU: Corsair TX750M  Peripherals: Rosewill
rk-9000, Gigabyte M8000x, Sennheiser PX 200-II, Asus VS247H-P 23.6" 1080p TN panel
https://linustechtips.com/topic/54714-3tb-hard-drive/#findComment-735622
