5 minutes ago, Arty said:
both will be Enough
get the skylake one.
What if the Aspire (Laptop 1) gets updated to Skylake CPUs? Should I get it instead? I was pretty much set for it until I saw the Dell's (Laptop 2) 8 GB of RAM, but with a significantly weaker GPU.
https://linustechtips.com/topic/546625-how-much-fps/#findComment-7226858
7 minutes ago, djdelarosa25 said:
Laptop 1:
i5-5200U, GT 940M, 4GB RAM
Laptop 2:
i5-6200U, R5 M335, 8GB RAM
CS:GO at 1024x768 medium settings
i would get the first one ( maybe upgrade the ram though ). The 940m is much stronger than the r5
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/546625-how-much-fps/#findComment-7226861
2 minutes ago, Sanderman135 said:
If Laptop 1 is significantly cheaper (seeing as it's an older processor) you could get that, and upgrade the ram and still get good performance and save some cash.
Laptop 1 is 670 USD. Laptop 2 is 760. Which one is more future proof?
https://linustechtips.com/topic/546625-how-much-fps/#findComment-7226887
I would just get the cheaper one unless it only supports 4 gigabytes of RAM. If it supports up to 8 gigs, just buy another stick. If not, get laptop 2. For reference I play CS:GO at 30 fps on low settings at 1366x768 with a Pentium N3700, HD Graphics and 8 gigs of RAM. You can configure the launch options for CS:GO for a bit more performance if you need it.
PM me if you need help with the launch options bruh.
My legit rig:
CPU: i5 6600k GPU: Asus Strix 1070 RAM: 16 GB of Corsair LPX CPU Cooler: NZXT Kraken X61 Motherboard:  Asus Z170I Pro Gaming Storage: Adata Sp550 120 GB and WD Black 3 TB Case: NZXT Manta Power Supply: EVGA 550 GS Monitors: 2 LG 25UM58-P Ultrawides Keyboard: Cooler Master Quickfire Rapid-i Mouse: Logitech G502 RGB
https://linustechtips.com/topic/546625-how-much-fps/#findComment-7226928
Probably laptop 2, it'll get better performance in cpu intensive tasks and just normal use, but it has a less powerful gpu so gaming performance isn't going to be great.
https://linustechtips.com/topic/546625-how-much-fps/#findComment-7226939
