Alright first off in single display mode it works fine. Ran 165hz with Gsync. As soon as I hooked up my 27inch Aoc that's when the gpu stopped down clocking below 900mhz. To get the gpu to idle normal I had to set the Predator back to 144hz and set the other monitor to 60hz. As soon as I did that back to 135hz at idle. Hopefully this helps someone if they run into it to. More of a dual monitor issue but.....
Edit. In Oc mode Playing a game on the Predator(main) panel was laggy also. Had to turn off oc to get rid of that to.
I7 5820k, Asus X99 Sabertooth, 980Ti Classified, 32gb Gskill Ripjaws 4, Corsair Rm1000i, Samsung 950 Pro, Custom Loop Xspc Cpu Block Ek Gpu Block, Windows 10, Define S. Acer Predator XB271HU
https://linustechtips.com/topic/546518-xb271hu-overclocking-issue/
