I'm looking at a xigmatek gaia for a heat sink that's relatively cheap and fits a socket 1155 preferably around the $30 to $40 USD range please help. so far the gaia is the best i also am looking at a EVERCOOL TTC-NK35TZ only if it works on 1155
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/5461-heatsink-help/
What are you using the heatsink for? Silence or Extreme OC?
not extreme over clocking and silence isnt to big of a deal but as close to a happy medium on both. just gonna overclock a bit nothing extreme and i dont mind the noise as long as everything is cold.
https://linustechtips.com/topic/5461-heatsink-help/#findComment-62039
The Gaia doesn't seem that bad then, 4-pin fan, decent weight. Should be fine with a 1GHz OC and fixed (low) fan speed within the BIOS.
If I was getting an Air Cooler I'd get the biggest and heaviest one I could find, most likely one of those Noctua NH D14's.
But for the 30-40 Dollar range I would be forced to get 212 evo. If you need to save the money, get the Gaia, It'll be a huge improvement over the stock box cooler.
https://linustechtips.com/topic/5461-heatsink-help/#findComment-62057
The CM hyper 212 plus/evo is pretty much the king of that price range. Slap a Scythe GT on it while they are still available and you are good to go.
gonna go with the plus thank you very much
https://linustechtips.com/topic/5461-heatsink-help/#findComment-62062
The Gaia is just as good as the 212 EVO juts at a lower price, so thats what id go for.
Intel Core I5 3570K @ 4.2Ghz w/ Hyper 212 EVO Gigabyte Z77X-UD3H 8GB Patriot Viper 3 1600Mhz CL9 Gigabyte Windforce 3X 7950 @ 1100/1550 Samsung 830 128GB Seagate Barracuda 1TB Fractal Design ​Define R4 Seasonic M12II 750Watt
https://linustechtips.com/topic/5461-heatsink-help/#findComment-62103
