Flaw #1: A Skylake cpu DOES NOT work with an LGA1150 motherboard. You need to get a new board
Flaw #2: The power supply is a little on the low side. I'd get a evga 500b psu as theyre quite cheap and reliable.
SYSTEM: CPU-i5-6600k GPU-EVGA Titan X SC MOBO-Asus Z170-A SOUND CARD-Asus Xonar Essence STX RAM-16GB HyperX Fury 2133 DDR4 COOLER-CoolerMaster Hyper T4 WIFI-Asus PCE-AC68
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219879
Thanks for that tip, any suggestions on mobos? And I'll change the psu to 500w <3
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219894
1 minute ago, Josephdalepi said:
better psu
get an ssd
people incoming: people get that processor because it is socket lga 1151, leaving room for upgrades
asus motherboards are better, and there are cheaper ones
Psu: 500w?
SSD: Maybe later down the line
People incoming: You called it
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219899
2 minutes ago, IrishSkittle said:
500w?
550W would be fine. An EVGA G2/GS/GQ PSU would be good as well as anything from XFX, Seasonic and Super Flower. Also, Antec's High Current Gamer lineup is great. For the motherboard, change to a B150 / H110 / H170 motherboard and change the RAM to 8GB of DDR4. Also, Asus AMD cards are not good so get one from anybody except Asus and Gigabyte.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219915
id get a asus z170-a. I have the same board and its good. unless if its an matx case. then im not sure.
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219925
Just now, IrishSkittle said:
Psu: 500w?
with a system like yours, if you upgrade anything, youll need a better one
ssd is more important than the hdd
hdds are cheap as hell and ssds are so much faster
keep the cpu, new mobo
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219928
http://www.mindfactory.de/product_info.php/4096MB-Sapphire-Radeon-R9-380-Nitro-inkl--Backplate-Aktiv-PCIe-3-0-x16--_1016531.html ?
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219970
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7219991
15 hours ago, IrishSkittle said:
Alright, so this is the final product: http://prntscr.com/a23gw6
Anyone else have anything to add? Or am I all good to go ahead and order?
P.S. any clue on how this can handle GTA V or Payday 2?
Can't speak for payday2, but GTA should be OK. You won't be blitzing it - would recommend an i5 for the extra 2 cores
Gaming/Engineering PC: -i7 6700K, 4-4.2GHz "Eleanor" -ASUS ROG HERO VIII MOBO -16GB DDR4 3000MHz Corsair (2x8GB) -Gigabyte Windforce 980Ti OC edition (1405MHz GPU clock) -H110i GT Corsair CPU Water cooler -980GB Sandisk Ultra II SSD -Corsair 450D ATX Case -RM850i Corsair PSU (Modular) -28” 4K Samsung -27” 1080p Samsung
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7223759
1 minute ago, Tautedorus said:
Do you really need a H97 motherboard? H110 or B150 will work fine with that i3-6100.
How about this?: http://www.mindfactory.de/product_info.php/ASRock-H110M-Combo-G-Intel-H110-So-1151-Dual-Channel-DDR3-DDR4-mATX-Reta_1014842.html
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7224008
Yeah, I was planning on upgraing the CPU down the line.
i know you've probably heard it many times - but saving now will be better for you.
if you would rather get it now (i understand that - i was in the same shoes in the past :P) then everything looks good.
Would recommend using PCPartPicker (give it a quick google, will be pretty high on the list) - this ensures that everything is compatible (down to power supply, correct sockets etc.). I disagree with the people above talking about increasing PSU wattage - this isn't necessary  but does make the PSU more efficient
Hope you enjoy your new pc!
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7224014
Yeah man, I've been waiting a while for this, I'd really rather get it now, and thanks for the advice <3
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7224018
3 minutes ago, IrishSkittle said:
A decent motherboard. However, I suggest you not go for the looks but for the price/performance on your build.
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7224032
10 hours ago, IrishSkittle said:
For now, I only see myself going for an i5 max
Your CPU is not what will take the power (it does take power, but only a little bit...) : It will be your gpu. AMD is more power-hungry than Nvidia so the more watts you get the better off you are when you get a second gpu or upgrade an existing one...
https://linustechtips.com/topic/546000-first-pc-build/#findComment-7227057
  • 2 weeks later...
