Best air cooler?
Solved by Kobathor,
5 minutes ago, Cvdasfg said:Thanks man I'll check those three out.
As far as the dark rock pro 3 vs the noctua NH-D15 by performs worse what exactly do you mean? how much worse? how in terms of performance compared to the evo i have now?
I read this as my source: https://www.techpowerup.com/mobile/reviews/Noctua/NH-D15/6.html
It's up against tons of coolers. They're really not that different, the Noctua pulling ahead only by a few °C. The bigger the thermal output, the farther apart they are, so consider that if you're going to OC hard on one of these coolers. Even the 212 EVO is on there.
