So i connected my Graphics card and installed drivers.....
after few trail and errors i got this thing running. but when i opened my far cry 2 things were not as expected. the game was slower!
here is GPU-Z and CPU-Z of my PC!
i have 2GB RAM
400W power supply
Rest is below
HELP!
https://linustechtips.com/topic/545102-8800gt-problem/
i have 2GB RAM
400W power supply
Rest is below
HELP!
Put the GPU back to its default clock. That's your problem.
i like trains 🙂
https://linustechtips.com/topic/545102-8800gt-problem/#findComment-7209779
Still using the 8800GT is the problem. :o
What kind of FPS do you get? What graphics settings are selected?
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/545102-8800gt-problem/#findComment-7209786
Check your GPU stats in BIOS and see what the clock speed for the 8800GT is.
https://linustechtips.com/topic/545102-8800gt-problem/#findComment-7209793
Just now, QasimAbbasi said:
Lol, iknow. but the problem is not that actually. im not getting what i must
If it is not set to 660mHz set it to 660mHz
https://linustechtips.com/topic/545102-8800gt-problem/#findComment-7209802
can i edit things in my bios?
and what should it be? and what must be changed? (I am a noob in these things)
I don't know, the options depend on what mobo/bios you have.
You should just try getting into BIOS and restoring all defaults and see if that works.
If restoring defaults doesn't correct your GPU's speed, the setting you want to look at is GPU clock frequency, find how your BIOS is recognizing the GPU(what frequencies)
https://linustechtips.com/topic/545102-8800gt-problem/#findComment-7209836
Be right back after trying this
https://linustechtips.com/topic/545102-8800gt-problem/#findComment-7209861
