need help upgradeing
Go to solution Solved by Amazingasian,
1 minute ago, gamazgaming said:
*850w
CORSAIR RM Series RM850 850W
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($249.99 @ Newegg)
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler  ($46.99 @ Newegg)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($157.98 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($69.99 @ Amazon)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X OC Video Card  ($389.99 @ Newegg)
Total: $909.94
Generated by PCPartPicker 2016-02-09 23:29 EST-0500
This would be the best price/performance PC here.
2 minutes ago, gamazgaming said:
hello im looking for help finding parts to upgrade. i have a amd fx 8320 and a gtx 960 and 16gb of ddr3 1866. dont think i need to upgrade my ram but im looking for input on my motherboard, cpu and gpu my budget is 900$
send help........
What PSU do you have?  Do you have an SSD?  What are your uses for this computer?
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/544865-need-help-upgradeing/#findComment-7206858
send help........
i5-4690K, R9 390.
Wait also is your budget for just those three parts $900 or a new rig?
https://linustechtips.com/topic/544865-need-help-upgradeing/#findComment-7206860
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97-HD3P ATX LGA1150 Motherboard  ($93.98 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.88 @ OutletPC)
Total: $743.85
Generated by PCPartPicker 2016-02-09 22:58 EST-0500
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/544865-need-help-upgradeing/#findComment-7206871
send help........
USDollars?
http://pcpartpicker.com/p/HfqqD3
https://linustechtips.com/topic/544865-need-help-upgradeing/#findComment-7206877
Exactly what 800W?  Some are good and some are bad.
https://linustechtips.com/topic/544865-need-help-upgradeing/#findComment-7207017
*850w
Total: $909.94
https://linustechtips.com/topic/544865-need-help-upgradeing/#findComment-7207045
Total: $909.94
thx man this helped
https://linustechtips.com/topic/544865-need-help-upgradeing/#findComment-7207061
