overclocking Overclocking CPU? Memory issue?
Solved by fire219,
For the RAM: Yes, you can just select 1866 and it should run at that speed. You can try the higher speeds. It may not be stable, but it won't damage anything. You would just have to set it back to 1866 or lower in that case.
For the CPU: Messing with the base frequency is usually a bad idea. Almost everything in your system is referenced to that clock, and changing it very far from stock can make things go very wrong.
