First PC Build Processor Core Advice
Solved by bomerr,
I don't like that build. You are spending 1400 on a PC and basically getting a bottom of the barrel entry level PC.
You can get windows from the usual places or get a copy of windows 7-8.1 and upgrade that to Windows 10.
For the monitor this is the link:
You can baseclock overclock that CPU to 4.2+ Ghz and overclock the monitor to 96hz.
Basically for 200 extra dollars you get a relatively high-end PC whereas before you were spending 1400 on an entry level PC.
