cheap power supply
Go to solution Solved by Dzzope,
FSP and Seasonic are also very good units... Your system would be fine on a GOOD 350 - 400W but with overclocking the card you may be pushing it... Very efficient cpu and power hungry GPU... your going to be right around the 400W mark I think but that will push the psu all the time.. 500W would be ideal.
hi guys i have a bitmore 650 watt psu i started thinking i have a bad psu bcz i have a g3258 and i cant pass 4.3 i tryed everything then i cant stabilize my r9 380 4gb msi stock the card is fine but i cant oc so if i keep the psu whats the dangers i dont have money for new one...
https://linustechtips.com/topic/543046-cheap-power-supply/
It's some cheap no-name, I wouldn't try OC on it.. You could get more stable power by running off a UPS, but I still wouldn't push it at all..
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184303
1 minute ago, TheRandomness said:
EVGA w1, b1, g1 units are not good... don't suggest them.. the GS, w2, B2, G2 are great tho.
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184306
Good luck finding any of that beneath $40.
Just now, proud greek said:
can you suggest me a good and cheap power supply?
Above $50 there's this: https://pcpartpicker.com/part/seasonic-power-supply-s12ii520bronze
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184314
I was going to recommend this: http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184323
thank you damnnn this sh*t on greece costs 73 euros my pocket is crying ;-;
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184324
Can you point us to where you'll be buying so we can see what is available and the price... Super flower, xfx and evga and sometimes AnTec are good price in europe.
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184336
well the site im using is like search and showing the shops that have the staff and you comparing the prices and then you order :P the site is at greek language the xfx is at 68,19 euros :P
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184349
If your really tight on budget the cheapest PSU I would consider for you would be this..
http://www.hardwaresecrets.com/antec-vp450-power-supply-review/11/
Just make sure it has all the connectors you need..
http://www.skroutz.gr/s/4706278/Antec-VP400PC.html
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184425
https://linustechtips.com/topic/543046-cheap-power-supply/#findComment-7184445
