Just now, Tomthedrum said:
Hi guys
I am planning a build for my brother and it should look like the one in the picture. How do you think I can mount the Mobo to the  Wood ?
Where do I get those PCIE slot covers? (where the gpu is screwed in)
Do you have any advise? I am pretty new to modding xD
dont
mod the hell out of the case you have
get some experience
you dont want to mess up doing something like that
https://linustechtips.com/topic/543030-crazy-build/#findComment-7184158
Lian Li makes some wall mountable cases, look them up. Pricey though
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/543030-crazy-build/#findComment-7184177
1 minute ago, Josephdalepi said:
modding the case you have
How am I supposed to put more fans in there? the case is meant to close the Rack up and take it somewhere. And the room inside the PC case is quite restricted so there is no room for tubing. Why should i watercool it, if i dont overclock
https://linustechtips.com/topic/543030-crazy-build/#findComment-7184195
thats not my point
what i mean is, try out lighter case mods
stick some fans in that one in the top for some cooling
make sure you know what youre doing and can do it before going for something like that
https://linustechtips.com/topic/543030-crazy-build/#findComment-7184199
thats not my point
The thing I am trying to build is a piece of wood and ontop there is a glasspane. Shouldn´t be so hard to screw up..
https://linustechtips.com/topic/543030-crazy-build/#findComment-7184204
Uhm are you searching for something like the ThermalTake Core P5? Its a wallmount Case so you can just buy it :)
http://thermaltake.de/Geh%C3%A4use/Midi_Tower_/Core/C_00002732/Core_P5/design.htm
Link is german but you can get what I mean :D
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133283&cm_re=thermaltake_Core_P5-_-11-133-283-_-Product
its a bit pricy though :/
Workstation: I7 4790K| Noctua NH-D15| Gigabyte gtx 660 OC| 16Gb Ram 1600Mhz| 2x FullHD 16:9 Monitors
Gaming rig:  FX6100 @ 4.5GHz| Club 3D radeon HD 7870XT Joker| 8Gb Kingston HyperX @ 2133MHz| MSI GAMING 970| 1680x1050 Monitor
Notebook:    Custom MSI GE60| I7 4710HQ| Nvidia Geforce gtx 860
https://linustechtips.com/topic/543030-crazy-build/#findComment-7194329
I was actually looking for this case :D Thank you
https://linustechtips.com/topic/543030-crazy-build/#findComment-7196203
ok no problem ^^
https://linustechtips.com/topic/543030-crazy-build/#findComment-7196212
I'm glad someone pointed out, but this is the case in the OP.  He not searching for something like it...it is exactly what he posted a picture of.
https://linustechtips.com/topic/543030-crazy-build/#findComment-7198133
