Logging in - small tweak
Go to solution Solved by colonel_mortis,
As has been said above, tab is the standard key to jump to the next field of a form, and enter always submits the form. That is stock browser behaviour, and will not be changed.
Just now, Wolf_Lbh said:
Not afaik. It has always been enter in the login box on any site I have used. Nice to know tab works though.
On a mac by any chance?
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7182184
Nope, I'm a strong opponent of mac products. (With the exception of their ipod shuffle 6th gen)
I know on macs enter works for everything
for me no site has enter working to go to PW
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7182195
I've never used software or website which would have enter as go to next field key. I know its used as such in some professional database software. But for Windows, Linux and majority of websites (all of them?) TAB is key to use for next field.
It would be counter-intuitive to change. Not only because majority of users are used to tabbing for next field. But if someone using screenreader or another accessibility software comes here, they get lost pretty quickly.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7182776
20 minutes ago, Wolf_Lbh said:
It's fine if you don't want to change it, but it isn't counter intuitive at all and worked great on every site/program I used it on. I for one am sad about this lack of progress.
On the facebook, twitter, twitch and amazon login forms, as well as most others, pressing enter submits the form rather than going to the next field. On Steam, pressing enter in the username field does nothing.
In none of the sites that I tested just now did pressing enter advance to the next field.
HTTP/2 203
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7184033
But why would you want to submit just your username and fail the login 100% of the time? Clearly this should be improved upon.
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7184062
That's why you don't press enter when in the username field...
It would be inconsistent if it went to the next field only if there were blank fields on the form, and inconsistency is widely regarded as poor UX design.
It is functioning in the same way as most other sites, which is browser stock behaviour. I don't really want to put in quite a bit of effort to override the browser stock behaviour, to make it non-standard and inconsistent.
HTTP/2 203
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7184086
I'm starting to get curious about which software/websites have it switched like that. I've used PCs or Windows 95 and newer OS since 90s and its always been tab for next field.
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7184438
55 minutes ago, Wolf_Lbh said:
So it doesn't do anything useful and it never will? Excellent design!
Well you use Enter to submit form. Rather than using Tab to jump yet another field. Its actually good design to have two buttons that do different things rather than having one button to do multiple things in same page.
https://linustechtips.com/topic/542824-logging-in-small-tweak/#findComment-7185685
