So i updated my motherboard bios. It said it was successful. Then when it starts up nothing has just a black screen. I was able to get to the bios menu. I check my ssd where my windows is installed. it says its in a frozen status. What does that mean? I have a photo so look. PLs help me. What do i do?
https://linustechtips.com/topic/542782-ssd-problem-pls-help/
Just now, CUDA_Cores said:
guessing you have tried unplugging the SSD, booting up into the bios, then shutting down the computer. Then plugging the ssd back in and turning back on the comptuer?
No i have not done that and let me try that. I will message you back and see if i works.
https://linustechtips.com/topic/542782-ssd-problem-pls-help/#findComment-7181681
In order for me to get into the bios i have to Remove the Cmos and then put it back. Is that normal?
https://linustechtips.com/topic/542782-ssd-problem-pls-help/#findComment-7181699
