3-pin is strict voltage control, 4-pin can be controlled by PWM (much more precise RPM control.)
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/542367-case-fan/#findComment-7177947
If it's labelled as a 3/4-Pin* it may either be a 4-pin or a 3-pin to 4-pin molex. 4-pin fan connectors will work on 3-pin fan headers (the pins on the motherboard). 3-pin is power and speed sensor (RPM). 3-pins require voltage regulation to change speed, that is to say you must increase and decrease the voltage. 4-pins are PWM as Kobathor said. PWM stand for Pulse Width Modulation. In case you don't know how PWM works, think of a cardiac (heart) monitor. PWM sends a pulse to the fan, each time it peaks it sends a pulse of 12 volts to the fan (12v in this specific application; PC usage). The pulse frequency changes to adjust the speed.
(Bad) example of PWM
_ = 0 volts, - = 12v
_-_-_-_-_
Edit
3/4-pin | A slash is sometimes used to me "to" so 3-to-4 pin, just explaining why I mentioned the 3-pin to 4-pin molex.
https://linustechtips.com/topic/542367-case-fan/#findComment-7178121
