Can you guys build me a 1100-1190 dollar gaming PC? I'm mainly gonna be playing CS:GO and Blacklight:Retribution, not much.. I'm probably thinking about overclocking but if it's not needed then I won't do it. I also need a 144hz monitor so that'll factor in the price as well. Thank you
https://linustechtips.com/topic/542151-help-with-pc/
PCPartPicker part list: http://pcpartpicker.com/p/DtHc23
Price breakdown by merchant: http://pcpartpicker.com/p/DtHc23/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($104.99 @ Micro Center)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory  ($40.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($308.98 @ Newegg)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($89.99 @ NCIX US)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($40.00)
Monitor: Acer GN246HL 144Hz 24.0" Monitor  ($207.58 @ Newegg)
Total: $1216.69
Generated by PCPartPicker 2016-02-06 01:44 EST-0500
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/542151-help-with-pc/#findComment-7175810
BCLK overclock the CPU. Although I don't know if Intel has any way of blocking that in the future, since they asked ASRock to remove the function from their mobos. I don't think MSI has been affected (yet).
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($215.99 @ SuperBiiz)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($111.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($37.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.72 @ Amazon)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  ($274.99 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Total: $1098.52
Generated by PCPartPicker 2016-02-06 01:51 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/542151-help-with-pc/#findComment-7175837
Total: $1098.52
What if I don't want to overclock just yet?
https://linustechtips.com/topic/542151-help-with-pc/#findComment-7175907
It'll still perform fine but it's essentially extra performance you're getting by OC'ing for free.
https://linustechtips.com/topic/542151-help-with-pc/#findComment-7175909
1 minute ago, immanueltja said:
would I get rid of the cooler and the z-170 motherboard? or keep it
You need both to overclock.
So I suppose you have to decide now if you want to overclock or not.
https://linustechtips.com/topic/542151-help-with-pc/#findComment-7175922
I won't overclock.
Then lose the CPU cooler and try to get a cheaper H170, H110, B150 motherboard.
https://linustechtips.com/topic/542151-help-with-pc/#findComment-7175929
what's the difference between each mobo?
The B150 is more oriented for business use and the H110 is just a stripped down H170 with less features. The H170 offers more features which you can read about here: http://www.tomshardware.com/news/intel-100-series-chipsets,29993.html
https://linustechtips.com/topic/542151-help-with-pc/#findComment-7175951
