Posted February 6, 2016 Please HELP with this. This is irritating on which is better??? Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 well the 390x uses more power.. but its a much higher performance card and will play games better than a 970. in a head to head graphics test the 390X would win, without a doubt. Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 | 9070 XT Homelab - many servers...constantly changing. 3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7175047 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 2 minutes ago, suchamoneypit said: well the 390x uses more power.. but its a much higher performance card and will play games better than a 970. in a head to head graphics test the 390X would win, without a doubt. yeah it costs a little bit more but still you could go with the r9 390 it is 2-3 fps worse, but you get $100 off Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7175066 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 Just now, bryceth01 said: yeah it costs a little bit more but still you could go with the r9 390 it is 2-3 fps worse, but you get $100 off keep in mind he said a 390X, which is not a 390. but even a 390 would be the better choice. the 390 is the direct competition to the 970 but is definitely the better choice. a 390x is mid-way between a 970 and 980. Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 | 9070 XT Homelab - many servers...constantly changing. 3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7175077 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 Just now, suchamoneypit said: keep in mind he said a 390X, which is not a 390. but even a 390 would be the better choice. the 390 is the direct competition to the 970 but is definitely the better choice. a 390x is mid-way between a 970 and 980. yeah i would go with the r9 390x good point Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7175083 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 6, 2016 That poll is impossible to answer because you've asked a conflicting question. It's like asking "which is faster and heavier, a semi truck or a Ferrari?" Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7175118 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 7, 2016 Author On 6 February 2016 at 5:09 PM, Ryan_Vickers said: That poll is impossible to answer because you've asked a conflicting question. It's like asking "which is faster and heavier, a semi truck or a Ferrari?" What do you mean which is faster? Obviously a Ferrari would win in most cases, it depends on the terrain. I do understand what you are implying Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7182826 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 7, 2016 12 hours ago, KrazyforOnce said: What do you mean which is faster? Obviously a Ferrari would win in most cases, it depends on the terrain. I do understand what you are implying Yeah, my point is that you can't answer because the cone that's faster is lighter, and vise versa. Just like the poll; the one with more power consumption is going to put off more heat and thus more noise (less silence). Just one possible example of how it doesn't work Solve your own audio issues | First Steps with RPi 3 | Humidity & Condensation | Sleep & Hibernation | Overclocking RAM | Making Backups | Displays | 4K / 8K / 16K / etc. | Do I need 80+ Platinum? If you can read this you're using the wrong theme. You can change it at the bottom. Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7186251 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted February 7, 2016 Author 5 hours ago, Ryan_Vickers said: Yeah, my point is that you can't answer because the cone that's faster is lighter, and vise versa. Just like the poll; the one with more power consumption is going to put off more heat and thus more noise (less silence). Just one possible example of how it doesn't work Ahhh true! Power consumption will conflict the possibilities of more noise and heat! Thanks for the help, really appreciated!!! Link to comment https://linustechtips.com/topic/542066-head-to-head-graphics-test/#findComment-7186968 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
