Skip all in one liquid coolers, get a be quiet dark rock pro 3, silent, looks good, preforms better, and no bloatware crap.
3 minutes ago, michael1423 said:
i have a i5-4690k and i want to do a decent overclock. and im going to be using the igpu for 1 month. and i was wonder which cpu cooler is better in performance and good looking.
corsair h105
or
corsair h110i
https://linustechtips.com/topic/540823-which-cpu-cooler/#findComment-7161967
corsair h105
or
corsair h110i
I heard people were able to get decent overclocks from a Hyper Evo 212, I saw one guy got his 2600k to 4.6ghz
https://linustechtips.com/topic/540823-which-cpu-cooler/#findComment-7161970
no a H105 or H110 has a lot more cooling power than the dark rock pro 3. I use a H105 with LTT fans and I get 60-70C at 4.2-4.4
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/540823-which-cpu-cooler/#findComment-7161974
Im talking for normal use, not running prime 95 for an hour strait. It can nicely handle overclocks.
https://linustechtips.com/topic/540823-which-cpu-cooler/#findComment-7161990
your temps seem high
under full load at 4.7 ghz i get 55 or less on an h100i
yay 9590
i still wish i had gone intel...
https://linustechtips.com/topic/540823-which-cpu-cooler/#findComment-7162090
yay 9590
that is with the fans spinning 600RPM. it is normal not ever above 55.
https://linustechtips.com/topic/540823-which-cpu-cooler/#findComment-7166790
