So I'm trying to get intel quick sync active on my computer, and I'm a bit confused. Is my motherboard not compatible with it? From what I understand, I'm supposed to go into the BIOS and enable something with the iGPU. But in my BIOS I see nothing about that.
        | CPU: Intel Core i3 4130 | GPU: PowerColor R9 270 | Motherboard: Asrock H81M-HDS | RAM: Kingston HyperX Fury 4GB |
|HDD: Western Digital 1TB | Case: NZXT Source 210 | PSU: Corsair CX430W |
| Mic: Blue Snowball iCE | Mouse: Corsair K65 RGB | Keyboard: Razer Blackwidow Chroma |
https://linustechtips.com/topic/540637-intel-quick-sync-help/
You trying to livestream / record using Quicksync? If so, then you have to enable your igpu in your BIOS, then use a program like OBS (Open Broadcast Software) and select Quicksync as your encoding method.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/540637-intel-quick-sync-help/#findComment-7159911
Generally to enable quick sync you just need to make sure that your integrated graphics are not completely disabled in your bios. There isn't a special option just for quick sync as far as I am aware, just making sure it is enabled.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
https://linustechtips.com/topic/540637-intel-quick-sync-help/#findComment-7159923
I'm having trouble finding anything about integrated graphics in my bios
Nevermind that, I found it in my bios and enabled it. From here I think I know what to do
https://linustechtips.com/topic/540637-intel-quick-sync-help/#findComment-7159927
