So I had to refresh windows 10 x64 on my steam box and Crimson did not work properly, OK uninstall and reinstall. Um Nope!
I have ran DDU multiple times and amd clean uninstall utility, but no avail.
Steam Box
i5 4690k
Z87 Gryphon
Sapphire 7950
edit. system is on ssd/hdd config
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
https://linustechtips.com/topic/540096-help-with-crimson/
Thanks for all the info, we can totally solve this problem of which we know nothing about
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154103
Do you not understand context? I have no display driver. Crimson keeps stalling/crashing under install. So LTT  where is the last reply is an asshat button?
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154135
Check event viewer for error or warning.
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154182
There is a known installer problem. Download the beta drivers and try again.
i7 6700k||Asus Z170-A||Powercolor R9 270X PCS+ 2GB||Bitfenix Prodigy M||16GB PNY Anarchy DDR4||Samsung 850 EVO 250GB SSD||Corsair CX850M power supply||Silverstone Tundra Series TD02-E AIO CPU cooling
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154193
Could be more specific with which beta driver? Thanks in advance.
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154202
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154238
Noice bro!
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154254
I had that issue crop up after some case rearranging.
https://linustechtips.com/topic/540096-help-with-crimson/#findComment-7154314
