Wiping hard drive
Go to solution Solved by daniellearmouth,
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/539200-wiping-hard-drive/#findComment-7144198
Just now, thatguyyouknow75 said:
how long does it take on average?
Depending on the size of the drive, the speed it runs at and the wiping method you use, it can take from a few hours to a few days.
DAYTONA
https://linustechtips.com/topic/539200-wiping-hard-drive/#findComment-7144299
