Hello to every one one the forum.
I would like help with making a parts list for my next $1500 build.  I already have a monitor picked out (http://www.microcenter.com/product/444614/Q2778VQE_27_Quad_Resolution_Monitor) but excluding that I don't really have any preferences as to what goes in the build.  I would however prefer that the build be white and purple themed with an included windows 8.1 copy.
https://linustechtips.com/topic/539082-help-with-pc-build/
Including the price of the monitor or excluding from the 1.5k budget?
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143021
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ B&H)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($102.88 @ Amazon)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory  ($74.86 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.98 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 4GB FTW ACX 2.0 Video Card  ($520.33 @ Amazon)
Case: Fractal Design Define R5 Blackout Edition w/ Window ATX Mid Tower Case  ($109.99 @ NCIX US)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($89.99 @ NCIX US)
Total: $1492.89
Generated by PCPartPicker 2016-02-01 15:22 EST-0500
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143023
is that $1500 inclusive of that monitor or 1500 just for the tower?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143029
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($253.89 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($153.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($52.99 @ SuperBiiz)
Video Card: Asus Radeon R9 390X 8GB Video Card  ($379.99 @ NCIX US)
Case: NZXT S340 (White) ATX Mid Tower Case  ($64.99 @ Micro Center)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($85.89 @ OutletPC)
Monitor: AOC Q2778VQE 60Hz 27.0" Monitor  ($299.99 @ Micro Center)
Total: $1551.47
Generated by PCPartPicker 2016-02-01 15:25 EST-0500
Boop!
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143060
Motherboard: MSI Z170A GAMING PRO ATX LGA1151 Motherboard  ($122.98 @ Newegg)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($89.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ NCIX US)
Total: $1179.58
Generated by PCPartPicker 2016-02-01 15:40 EST-0500
Get windows from g2a etc for like $40
Ryzen Ram Guide
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143090
Welcome to the forums!
and people like it a lot more when you use http://www.pcpartpicker.com because it allows us to edit and add stuff easier
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($89.99 @ Newegg)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  ($493.98 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($133.99 @ NCIX US)
Total: $1463.58
Generated by PCPartPicker 2016-02-01 15:30 EST-0500
I chose the CPU because of the Price to performance that it has and is really the best skylake overclockable CPU in my mind
The cooler is just a nice cooler and will do the job nicely if you ever wanted to over clock
The storage is a great config because you have a ssd and a hdd so you can install your OS and most played games/ used programs on there and just dump other stuff on your mechanical hard drive
The GPU is by far the best thing in this computer you will be able to play any games for the next 4-5 years on this GPU.
I sorta just put the case in there as a place holder, the enthoo pro is a great case (I have the enthoo luxe, its basically the same thing but with LED Lights pre-installed) but any case around that price would be good, such as the mastercase pro 5 from cooler master.
Now that power supply is great 850 watts is all the power you will ever need in case you ever wanted to add another GTX 980 down the line. and it is 80 plus platinum efficiency
Hope I was able to help. :D
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143143
Total: $1463.58
It's $1500 including the monitor, so $1200 for the build
Ryzen Ram Guide
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143147
3 minutes ago, PC_Master_Race said:
other than what stealth said it is a really good build
I modified the build a bit. Sorry I must of not seen $1500 with a monitor
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($54.99 @ Amazon)
Video Card: MSI Radeon R9 390 8GB Video Card  ($323.98 @ Newegg)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Total: $1224.58
Generated by PCPartPicker 2016-02-01 15:44 EST-0500
Mainly I made it 8gb of RAM, a 390 and a slightly less power supply but will still be good even though it is 80+ gold
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143208
Total: $1224.58
I like this build as well thank you all for the help now time to choose
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143222
@PC_Master_Race
Total: $1179.58
Ryzen Ram Guide
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143228
2 minutes ago, stealth80 said:
@PC_Master_Race
Total: $1179.58
I do like this build as it leaves a little wiggle room even with the monitor in for things like fans and possible case changes.
https://linustechtips.com/topic/539082-help-with-pc-build/#findComment-7143244
