I have made a video showing what happens, my temps are fine under load, but while opening simple things it spikes, Here is the video, Please watch in 1080P.
And i have just replaced the thermal paste..
| CPU: Core i7-4790K  |  Motherboard:  MSI Gaming Z97 GAMING 5 LGA 1150  |  CPU Cooler:  NZXT Kraken X61 |
| GPU: Single 8GB EVGA GTX 1070 FTW |  RAMCorsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz |  CaseCorsair 330R Titanium Edition
https://linustechtips.com/topic/538484-cpu-temp-spiking-while-doing-simple-things/
Do you think its worth RMAing?
1 minute ago, CUDA_Cores said:
try the good ol' reseating the CPU cooler and reapplying the thermal compound yet again. If that doesn't work you may want to try using a different stress test program like asus realbench and see if you still get temp spikes.
I have tried that....
The only issue i see here is that the CPU is consistently sitting on 4.4 GHz.
Have you over clocked it?
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
No i put it on performance in windows 10 power settings.
55c isn't even near the threshold you need to start being worried about your cpu over heating. Does it over heat when you stress test it if not then your all good and no need to worry.
[CPU-i5 4690k] [MB-Asus Maximus VII Hero] [GPU-Asus Matirx 980ti] [Ram-8GB Corsair Vengeance ram] [ Cooling-Corsair H100i/ 3 Noctua NF-P12 for intake] [sSD/HDD-120GB evo/ 1TB WB Caviar blue] [Case-NZXT H440] [Dell U3415W]
Then it's running constantly at max turbo boost speed on one of the cores likely the one that is spiking if there is only one.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
It does it with it on balanced too.  it does not matter what i change or do, it still spikes.
Will it thermal throttle at 60c?
Don't bother telling him. He's made over 10 threads about his CPU temps by now and everyone tells him the same thing.
My ~$200 USD build:
AMD A8-7600    G. Skill Ripjaws Z @1800 CAS 8     EVGA 500w 80+ PSU    Gigabyte GAF2A68HM-DS2H Motherboard
Nope pretty sure the haswell chips don't throttle till your close to 90c.
Nope,  go away. stop being a troll.
If it is only one of the cores then it is the turbo boost (since you already remounted and the temp isn't that high), high performance just keeps the clock speed a max all the time making the machine idle at higher temps.
Do i have a faulty chip?
Everyone can go to your profile and see you have over 5 pages of topics you've posted. All you do is spam the forums.
My ~$200 USD build:
good.
No since it isn't throttling you have no issues, when cpu use spikes temps do to for an instant then they level off
So i my chip faulty?
so thats the case with mine? And i dont need to monitor temps anymore?
I still monitor just because but there is no need so long as temps stay below 80C for daily use and don't go above 85 if being stress tested, you can shoot for lower temps if you want but if the temps stay below those figures it really doesn't matter.
So i am 100% fine?
So i am 100% fine?
yes
