First PC Build?
Solved by Streetguru,
39 minutes ago, TrevorTechTips said:Yeah, I perfer the drivers plus features such as Shadowplay. ;)
Pretty sure you meant polaris man, also if I'm not mistaken AMD has the same/similair software options compared to shadowplay
however I wouldn't recommend shadowplay anyways, as you have far more control over your files using OBS, possibly in conjunction with DXtory
In addition you're going to save money on an adaptive sync display with AMD cards, and we gotta wait and see if nvidia fixed it's DX12 issues on pascal.
