Looking at my building my first loop, but looking for fan suggestions for radiators. I will have an alphacool nexxxos 120x30mm rad, and a separate nexxxos 92x45mm rad.
So far, i am thinking of noctua nf-f12 for the 120, and am between noctua nf-a9 pwm and arctic f9 pwm for the 92.
Basically, need help deciding mostly on the 92 mm fan, although suggestions for 120 are appreciated as well.
Color is somewhat important. Would looking into painting the nf-a9 if i went that route as it will be seen in the case. nf-f12 (or whatever i use for the 120 rad) will be hidden, so not as big of deal.
I'm looking for high static pressure, high airflow, but quiet (25db or so).
Hopefully someone has experience with a 92mm rad here...
also, for any difference it might make, 120 will be pushing through rad, 92 will be pulling (as the plan so far)
https://linustechtips.com/topic/538372-fan-suggestions/
try these;
 CHRISTIAN MEMBER
https://linustechtips.com/topic/538372-fan-suggestions/#findComment-7136014
I'd highly recommend against a 92 mm rad. Fans just don't push enough air without being stupid loud for it to make sense (personally I also feel that way for 120s instead of 140s, but it's a huge difference).
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/538372-fan-suggestions/#findComment-7137512
i would use the same size fan for rads for both push and pull. for the hidden fans, you cant beat noctua for stealthy airflow. if you need something more flashy thermaltake has new static pressure riing fans to add some flair. those will be the ones i go to when im ready to build my loop. other ~25 db fans (based on my experience) would include thermaltake riing fans, and enermax fans
currently my rig has 2 140mm red riing fans on the front, 1 noctua 140mm fan in the psu (that was an enlightening mod), 2 120mm riing along with the stock fns for my h110i cooler, and 2 enermax 120mm red led fans on the bottom pushing air into the rig. total db rating when gaming is 25-30. at idle its at 25 max
Chief of the Red Hands multi-gaming group
https://linustechtips.com/topic/538372-fan-suggestions/#findComment-7141288
