I have a problem with my western digital external hard drive (1 tb my passport) Its not functioning properly as seen below. Everything lights up well, but when i plug it, thats what happens. It doesnt even wanna show the right name with should be (My Passport). These are what i tried and its results
I tried to:
Format it: Unable to format
Open it: Either that folder freezes causing my pc to freeze/ It says insert disk
Open disk management: Its stuck at "Connecting to virtual disk" ONLY when that hard drive is plugged
Open its properties for chkdsk: It doesnt want to open and it also freezes
Format the hard drive using cmd: Unable to format also
Uninstall the driver in device manager: It never finishes, i tried leaving it to uninstall for about 5 hrs straight, yeah its still there, my guess is that it froze there.
YES I HAVE TRIED ALL THESE ON ANOTHER PC, SAME RESULT
Is there anything i can do? I dont mind wiping all the data, or losing all of it. As long as it can become usable again.
https://linustechtips.com/topic/538001-external-hard-drive-problem/
Did you check the smart status? Because I have seen number of external disks begin their journey to the bin with this type of behaviour. You can use http://crystalmark.info/software/CrystalDiskInfo/index-e.html as its probably the most versatile soft for getting smart status from external disks.
Aside of sometimes just a cable gone bad or bad USB port. :)
ASRock Z97 PRO 4| i7-4790К@4600MHz/1.26V| Noctua NH-D14| 16GB ADATA@1800Mhz| Gigabyte GTX 660 WF OC| Samsung 840 Pro 128GB; Samsung 860 Pro 256GB; Samsung 860 EVO 500GB| Seasonic SS-650KM3 Gold| CM Storm QuickFire Ultimate| Mionix Naos 7000|
