Hey, i got reccomended by a friend to use this forum for help for a certain game.
so yeah, basically, i have a 55' 4k screen for my PC monitor. Since getting the screen i'm having problems with a certain game, MX Simulator. I only have problems with this game so i dont know if the screen is the problem or if the game is the problem. I used the Mx Sim forum to look for help but so far nothings helped. You can see that forum post here: http://forum.mxsimulator.com/viewtopic.php?f=17&t=38187
However, i'll try and briefly sum up the problem here:
i used to get 125fps on max graphics, whether it was single player or online, now i get a flickery 28-32fps on the lowest of graphics which makes a game like MX Sim pretty much impossible to play. If i mess around with video settings it will jump from 28-32fps and will go to 58-62fps but has lag spikes
Any help would be appreciated, thanks
https://linustechtips.com/topic/537980-4k-lag-issue/
make sure you have the tv/panel in game mode if it has one.
also make sure that you're connected to the screen using HDMI 2.0 (you need an HDMI 2.0 compatible graphics card). HDMI 1.4 doesn't have the bandwidth for more than 4K 30Hz which will look laggy.
otherwise, possibly more a software issue with the game.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/537980-4k-lag-issue/#findComment-7132957
Well, that's seems about right to me.
Unless you have two or more, high end GPUs, forget about gaming in 4k. The hardware is just not there yet to enjoy proper 4K gaming. This is why next to nobody is recommending anyone to get a 4k monitor for gaming.
I suggest you just go in the config of your games, and reduce the resolution back to 1080p/1440p or something like that.
But just as a side note, what resolution was your previous monitor and what is your current PC's specs?
https://linustechtips.com/topic/537980-4k-lag-issue/#findComment-7133237
Depends on your hardware really, my desktop plays most games just fine in 4K (dual GTX980's)
https://linustechtips.com/topic/537980-4k-lag-issue/#findComment-7133428
That's also why I said "unless you have two or more, high end GPUs".
I'm guessing the OP either has a single GPU or a few lower end ones. Which isn't adequate for 4k gaming just yet.
https://linustechtips.com/topic/537980-4k-lag-issue/#findComment-7135001
