2 minutes ago, VeryDogeTV said:
it dosent work in the Blue USB Ports
I suspect you don't have the USB3 drivers installed
check Device Manager and see if any devices have a yellow "!" mark - or better yet, post a pic of your device manager with expanded USB controlers
check Device Manager and see if any devices have a yellow "!" mark - r better yet, post a pic of your device manager with expanded USB controlers
http://imgur.com/AteeIDu
Is there any chance u can put the HDD directly into ur pc?
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
4 minutes ago, VeryDogeTV said:
yes, you do have the USB3 drivers installed .. strange
can you test this external HDD on a friend's PC/laptop ?!
would be nice to know what the popup in the video said .... ;/
It's probably the controller inside of ur external hdd. If you can remove the HDD out of its housing and put it in a new one, it'll probably work.
Have you tried another cable?
have not tried another cable, didnt got the idea, since its the original cable that came with the HDD
If you wanna go the safe route, get something like that:
http://www.amazon.com/Joylive-Ultra-Drive-External-Enclosure/dp/B00WLYWOS4/ref=sr_1_4?ie=UTF8&qid=1454254455&sr=8-4&keywords=2.5%22+external+hdd+housing
If its still failing after u put the hdd into that enclosure, its the hard drives fault.
Edit.: Can you post a picture of the bottom side of the Hard drive?
i got a rubber enclosure, there was the same issue with it put on
ill try to translate it
It's not the enclosures fault, i think. The controller, which converts the hdd's sata port to USB is probably failing.
so underneeth is a normal SATA connector? i could try plugging it in my motherboard with a sata cable if there is a connector
Thats why i wanted u to put a picture in here. (bottom side)
Just now, zMeul said:
neah .. that's the way it is
the assholes removed the SATA ports and put a USB controller on board
Never heared of smth like that o.O Thats programmed to fail some day ^^
http://imgur.com/UoHsgub
