So im planing to get an i7 4790 and a gtx 680 and im afraid that the gpu will bottleneck and im on alow budget i cant afford more expensive gpus so have to stick with the gtx 680
Plz note that i cant get gtx 960 or higher cuz the 900 series here in my country are expensive
I was planing on getting a i5 4460 but i saw that i have couple of bucks left in my pocket but i dont want to regret anything
https://linustechtips.com/topic/537284-will-there-be-bottleneck/
get the i7 first and use the igpu until you save enough for the 900 series, it will be worth it
https://linustechtips.com/topic/537284-will-there-be-bottleneck/#findComment-7125562
Will the GPU be a bottleneck? Yes, but that's normal :). Even with a 980ti the GPU would be the bottleneck most likely
https://linustechtips.com/topic/537284-will-there-be-bottleneck/#findComment-7125567
