New build help
Solved by TonyStark,
Hello. first things first...there is no "real" future proof machine....the rule is.."the more money you spend the more is going to last but eventually you'll do it all over again"...Both EVGA & Corsair are good brands and have nice products. So far the internals of Corsair PSUs were made by PC power & cooling which are one of the best there are in my opinion. If you are planning to get a better (or more than one GPUs) later on I'd say you go with the bigger one...either ways since all the PSUs are switching PSUs they only draw the power they need and not all the power they can. Last but not least its what your pocket can handle....
