i was using msi after burner to measure fps when i noticed the cpu was running at 96 degrees.... so i checked on another program and it said 66 degrees
i have a i7 2600 with a stock cooler
Which program showed lower temps ?
https://linustechtips.com/topic/536326-cpu-temps/#findComment-7114185
Use Real Temp as it was built with Intel CPUs in mind
https://linustechtips.com/topic/536326-cpu-temps/#findComment-7114211
Use HWmonitor, Trust HWmonitor.
According to HW Monitor I have no +12V rail and my CPU runs at 154*C
https://linustechtips.com/topic/536326-cpu-temps/#findComment-7114214
Try CoreTemp as well.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/536326-cpu-temps/#findComment-7114248
Core Temp is for AMD mainly
well fuck it is running at 96 degrees
Well, time to reseat the cooler
https://linustechtips.com/topic/536326-cpu-temps/#findComment-7114322
